charge controller
  • rouge
    • May 2010
    charge controller
    Hi,
    I am in the process of building a RE system and the only problem that I have left is the charge converter. I need a charge converter than can handle 30-40A but I don't really feel like spending the 150-300 for a commercial one that has all the bells and whistles on it. I just want something simple, could anyone point me in the direction of one thats either much cheaper on the market or something I could possibly build myself?
    Thanks
    You connect you panels to the battery, and measure the voltage with a meter. Disconnect the panels when the battery is charged. That's the cheapest.
    If your panels are closely matched to your battery voltege, the TRACE/XANTREX C-60 is a well proven controller.
    $190 http://store.solar-electric.com/tracc6060amp.html PWM, not MPPT
    • jamesbrush
      • Jul 2010
      I feel that there is some problem with charge converter. Try any other charge converter then look the difference between voltage between them.
      [url=http://lcit.co.uk/]SAP Training UK[/url]
      • rimpa001
        • Jul 2010
        • 0
        Originally posted by rouge
        Hi,
        Thanks
        I feel the same as James..Try changing your converter..Thanks
        I often answer posts with nonsense answers, maybe because I am trying to get my post count up to evade moderators.
        BEWARE - Watch me
          Thanks
          The C-60 I mentioned earlier, is a solid product. Even a used, working one from ebay shoud be acceptable, insist on a photo of the innards to insure it's not been BBQ'd
          How much will it cost to replace a destroyed battery bank, and the structure that houses it, if a cheap or non-skillfuly made controller fails? The likelyhood of a C-60 failing is very low.
          • MarineLiner
            Solar Skipper
            • 656
