Hi all,
I've run into a very weird problem with an off-grid system I'm trying to get working. I'm inexplicably losing 20% of my battery's max capacity after each charge/discharge cycle.
Here's my system:
Solar panels - 650 watt
Charger - 24V 60A MPPT solar/grid charge controller
Battery - 2x24V 200AH (4x100AHx12V) Yuasa Maintenance free sealed lead acid deep cycle batteries
When I bought the batteries I tested their capacity by applying a 900 watt DC load until voltage dropped to 23V while under load. This should have reduced the state of charge to 30% and spent about 3 kWh.
I then immediately switched to charging the batteries, with a three-stage MPPT charger. Instead of using the PVs I set it to charge 20 amp from the grid to make calculations easier. Bulk charging restored 1.5 kWh during three hours until the voltage reached 29.2V at which point it switched to absorption charge until the batteries would accept no more charge. Total charge was only 2 kWh. After a nightโs rest the batteries showed a 26V full load. They wouldn't accept any more charge, but the magic eye indicator which had showed green before never floated up again.
Several times more I repeated this same experiment, each time the batteries could hold the load for shorter periods, losing about 10-20% of their max capacity at each cycle until stabilizing at about 40%, or 80AH. At this stage the acid density for the batteries only goes from 1.10 g/ml when discharged to 1.15 g/ml at full charge, but at full charge they still show 26V, SOC 100%, while at rest.
I suspected acid stratification, but shaking the batteries to mix the electrolyte made little difference. I then tried to charge the batteries with a regular 24V car charger, but it too was unable to charge the batteries any further. I also tried equalizing the batteries by applying a soft (6A) 24+6V overcharge to the batteries for two hours, but they still refused to accept any more charge. Finally, I assumed the batteries were damaged and replaced the entire battery array (Yuasa L35-100) with four new batteries instead (Yuasa L36-100, fresh batch from retailer). However, repeating the charge/discharge cycles gave the exact same result and the capacity of the new batteries was reduced to ~40% within just a few days.
I'm at a loss for ideas on how to restore the battery capacity, or why the max capacity is diminishing so quickly. Or why the battery voltage is showing a full charge even when the acid density is so poor. If you have any suggestions please share.
Here's my system:
