Hi all,
My first post here and pretty new to solar so please be gentle! I probably know just enough to be dangerous!
(I have searched but could not find anything similar - please point me in the right direction if this has been asked before)
I've just completed a solar thermal water system (which works very well) but I would now like to run the whole thing from a solar pv panel and small battery. The solar water system is all 12v, with the following component ratings:
Controller: 2.5 watts (on 24/7)
pump: 14 watts (on pretty much constantly from 0900 to 1830)
3 way valve: 1 watt (once activated, potentially on from 0900 to 1830)
Heat dump fans: 30 watts (potentially could be on from 0900 to 1830)
So, what I want to do is fit a 120 watt solar panel to run everything during the day. I would also like a small 7Ah battery so that when the sun goes down, the battery can continue to power just the solar thermal controller only. (I already have the 7Ah battery, which I would like to re-use).
I know I need a charge controller to condition and stabilise the day time load and to control the charge to the battery, but....how do I limit the charging current from the panel and charge controller to the small 7Ah battery. I am assuming that a charge controller rated to handle the 120 watt panel will allow too high a charge current to the battery if I just connect it directly to the charge controller? I think I would like to limit battery charging to about 500mA.
Am I on the right tracks or could you offer advice on a more suitable way to do it please?
Is there a suitable or recommended charge controller for my application?
If not, what else needs to go between the charge controller and the 7Ah battery to basically just trickle charge and then float charge it?
Many thanks in advance for any information and suggestions.
Steve
Steve
