1. Make sure the electrolyte level is at the recommended level, but not overfull since there will be some gassing and expansion. But by all means above the plates.
2. Measure the voltage and SG, in case you later have a concern about the condition of the batteries as received.
3. Charge them with a standard AC-input 3-stage charger using the voltages recommended by the battery manufacturer. Note: (Thanks Dereck!) Using a 3-stage-capable charger does not necessarily mean using a 3 stage charge profile. If the manufacturer recommends a non-standard profile for initial charge, set your charger up to follow that profile.
4. If you have to run a generator to do this, go ahead, as soon as possible to preserve the health of your batteries, and definitely before using them to supply a load.
5. If this means charging the batteries up individually rather than in their final configuration, go ahead and do that.
6. You want to get the batteries to at least 80% SOC if they are not there already. Above that point it is good to go to full charge, but not quite as urgent.
Others may disagree of have additional suggestions.
