I have 16 six volt Deka 8L16 batteries in series/parallel to make 48 volts with a 740 amp hour capacity in an off grid home. I have 4200 watts of panels on two arrays and two outback charge controllers feeding the batteries with a generator as auxiliary 120 to the home and charger through a magnum inverter. The system is just over 4 years old and going into its 5th year. I think the batteries are showing signs of failure based on their drop in voltage after 20% use overnight. I am using a Bogart Engineering meter to group the two arrays and the single battery bank to measure capacity.
After charging the batteries to 100% at the end of the day with the voltage in the 50 volt range, but not 51 volts, overnight the batteries will drop to about 80% of capacity with the use of heat and appliances. (just as a caveat, the voltage will rise to 56.6 or so during the day when being charged, but never over 57 volts unless under equalization. There again, I can't get the equalization volts of the batteries to go to 61 volts even though the charge controllers are set that way) When the meter says the batteries have 80% to 85% of capacity, and the heat is on with the total system drawing 15 to 25 amps depending on what is going on, the volts will drop to 41.5 to 43 and recover to about 44 volts if the use drops to 9 amps after the heater(s) kick out. So I am left with the meter showing capacity around 75% to 80% and my voltage is around 42 to 44 with low amp draw of 7 to 9 amps.
Question: Does this indicate that my batteries are no longer at the 740 amp hour rating and have lost their capacity and may only have say 400 or 500 amp hours and the 80% capacity is really more like 50% or so?
Please chime in with advice, your experience and education.
I am going to replace this set up with some Surette S600 batteries so I'll have 900 amp hours. Maybe next time, I'll go to a 2 volt setup with even more amp hour capacity. What say you?
