Will this configuration damage batteries ?
  • sibitg13
    • Feb 2021
    • 3
    I am planning an off grid system with below specification:
    1. Panel - 330w 24v x 4
    2. Battery - C10 12v 150ah x 2 in series
    3. Inverter - 2.8kva 24v
    4. MPPT - 24v 50A
    Assume I am using an average of 1000 watts from 6am to 3pm. After that around 300 watts average. Maximum will be 2200 watts from an Induction stove for a short period.
    My concern is whether the battery capacity is enough for this system.
    If not, what is the maximum inverter capacity suitable for this battery system?
    I can not increase the battery capacity due to my budget.
    Thanks in advance.
    Nope. Your 1,000 watt 6am-3pm is going to consume ALL the power from your PV, with nothing left to recharge the batteries.
    Effective sun is only 10am - 2pm. So you have to plan your total harvest in those hours to both run loads and recharge the 6am - 10 am loads.
    This will be a large 48V system
    • sibitg13
      • Feb 2021
      • 3
      Thank you very much.
      So I need to reduce the load further, since I do not have budget to increase capacity now.
      I think I will remove the Induction stove and reduce consumption after 12pm, let me see.
        That's only going to make a small dent. The 1kw drain from 6am to noon, works out to be 6kw, plus the rest of your day. I have a large 48V system and my daily winter budget is <7kwh and < 12kwh in summer when water pumps run.
        Both your battery and your PV is too small.
        That load (w/o stove) is
        ( 9kwh ~ 1kw for 9 hr) & ( 4.5kwh ~ 300w for 15 hr)
        13.5kwh daily load. needs a 70kwh battery. At 48V, that's a 300ah battery bank. That bank needs about 40A to properly charge, so a 3kw PV array would be needed
        [ generic back of the napkin guesses ]
        • sibitg13
          • Feb 2021
          • 3
          Thank you Mike.
          I need to rework my plan.
          Details were really helpful, otherwise I would have invested in this system.
