Trojan RE vs others?
  • PNW_Steve
    • 433
    Hey Everyone,
    I am ordering batteries and had picked the Trojan L16RE-B SOLAR SPRE 06 415 6V 377 AH BATTERY for $329 each. Then I found TROJAN L16P SOLAR SSIG 06 475 6V 428 AH BATTERY for $319 each.
    An additional 51 a/h for $10 less.
    Other than the difference in a/h I don't see what the difference is? Can you all tell me anything more about these two?
    Btw: These are house batteries for my RV.
    Thanks.
    ​​​​​​​S.
  • Salts
    • Sep 2019
    • 216
    I would go with their SIND line.. The Trojan SIND bats are far superior to everything else except maybe a Rolls. They even put lithium down in some ways.
      • 15156
      Originally posted by PNW_Steve
      Hey Everyone,
      Thanks.
      ​​​​​​​S.
      Hard to say why the higher Ah rated are cheaper except like all things that are sold cheaper sometimes means they are clearing the shelves of slow moving items or a newer revision is coming.
      • PNW_Steve
        • 433
        Any info on the difference?
        One is labeled "solar" and the other is labeled "RE".
          Yeah I can tell you the difference.
          SSIG series is an entry level battery with a 1 to 2 year warranty
          SPRE series is a mid range level with a 5 year warranty. They have more lead in them.
          IND is top of the line 10 year battery.
          You want in order IND, SPRE, and last SSIG. As much as your wallet can afford.
            Wow - just like counting lug nuts after an auto accident, the one with the most lug nuts nearly always wins.
            in this case, the most weight wins.
            There may be a trade off between cheap cost and short life and high cost long life.
            If this is your first install, use the cheap ones. Any mistakes you make, you destroy cheap batteries, not the expensive ones. After you get the cheap ones to last for 2 years, buy the expensive ones, or maybe there will be viable Li batteries by then.
            • PNW_Steve
              • 433
              Thanks for the suggestions. Not my first rodeo but I may follow your suggestions anyway. My NAPA GC-2's in my travel trailer turn 6 this year and they are showing a definite loss of capacity. I think that I will see how much life I can get out of the cheap ones and start saving my pennies for IND replacements down the road.
              • PNW_Steve
                • 433
                Thank you. That answers my question.
                • paulcheung
                  • Jul 2013
                  • 965
                  Also, Trojan said the IND and SPRE line come with Smart Carbon Technology.
                  Since 1925 Trojan Battery Company been a leading manufacturer of deep-cycle flooded, AGM, and gel batteries as well as our new Trojan AES and lithium-ion batteries.
                  • PNW_Steve
                    • 433
                    Thank you Everyone.
