in my 5th wheel i have added two L16 6v batteries in series. The charging specs per the manufacture is 14.8v for both bulk and absorption. However the built-in converter/charger (Progressive Dynamics PD4575) charging profile is 14.4v bulk and then drops to 13.6v for absorption. I'm looking at adding a Xantrex inverter/charger that has ability for a custom charging profile to meet the batteries charging specs. Do I leave the existing converter/charger in place or does it need to come out. It's a separate component to the overall Progressive Dynamics power center, and can just be removed. If I do that, all the 12v loads will come from the batteries even when connected to shore power??
I'm assuming the Xantrex will kick on to keep the batteries fully charged when 12v loads occur. Doing it this way seems to force all 12v loads when connected to shore power to have to pull from the batteries vs. being satisfied by the existing converter.
Any issues with putting 14.8v into the trailers 12v wiring harness and thus to all 12v components, like control panel, fans, slide-outs, lights, etc. while charging???
Does wanting to add solar panels on the roof in the near future have any impact on this solution?
