About to buy an AGM battery bank. Anything new or economical I should consider?
It can be done but one needs to know how to wire the loom and understand the why in detail. If ones does not get the loom correct, some batteries in the bank will receive more charge, others will be discharged harder, resulting in a unbalanced battery bank. Without going into protracted detail, a unbalanced battery bank is self-destructive. Then there are variables that the best loom cannot factor out. The only way to deal with the variables is higher battery maintenance or accepting a shorter battery life span.
On the other hand, a series loom is almost .. almost idiot proof.
Some other engineers here recently installed several new AGM batteries at a solar site. They tried hard to make the wiring to all batteries equal. For fun I went up and measured the charge currents to each battery on a sunny day. The currents were (rounded to the nearest quarter-amp) 6.5 A, 6A, 8A, 6A, 4A, 8A, 3A, 8A, 5A, 8A, 8A, and 7A. These are all new batteries wired in a way that they thought would make the currents equal. It showed me first hand why parallel cycled batteries is a bad idea.
This is all good info, I wish I had known.
So, what do you guys think of a bank of 6 of these? http://lifelinebatteries.com/product...es/gpl-4ct-2v/
They're expensive and heavy. But lifeline is a good brand. How would I maximize their health with my current setup?Comment
MSEE, PEComment
MSEE, PEComment
Ignore this guy. He is dangerous and does not know what he is talking about.Last edited by Falsa_Nominis; 03-31-2018, 03:05 AM.Comment
A massive parallel bank (3 strings) containing series batteries (6v x 2)
What steps can I do to maintain a 6 battery bank (3 parallel in 2 series) at 660AH?
If you are unable to contribute meaningful input, but just want to type and raise the noise level, we'll oblige you with vacations from the forum.
17 posts and gone, might be a new record. It seemed from his opening post he had a chip on his shoulder.
2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
In Float Service, the batteries will equalize in 24 hours. You do not have that luxury of time with a daily cycle battery, and you get the double whammy with solar as you only have a few precious hours to try to get fully charged which you can never really do anyway. So parallel batteries in solar just compound the problems.
Now having said that an RV is a bit of different application. As long as you do not use the RV on a daily or regular basis, you can get away with parallel batteries without a huge hit on cycle life. That is providing when the RV is parked at home in between trips you put the batteries on a commercial AC charger with a Float voltage setting and disconnect solar. A lot of people do not understand the so called smart chargers (Multi-Stage) are hard on batteries. They are used to speed up charging which is required for daily cycle applications. Float Chargers aka CC/CV are the gentlest charging algorithm, and put the least amount of stress on a battery. They never go above gassing voltage.
MSEE, PEComment
I will be working in the field most of the time and almost never have access to shore power. So, I won't be able to do that. I'm going to follow your advice and do a series of 6 x 2V batteries, of the Sun Extender variety. Thanks, guys!Comment
Those batteries pack a lot of punch and can easily pump 10,000 amps into a dead bolted fault which is more than enough to vaporize 1/0 copper wire. Hot enough to burn your flesh to the bone in an instant and set steel on fire. God cannot help you if there is any aluminum or magnesium around.
