Classical batteries
  • Gdwats
    • Jul 2017
    • 207
    Classical batteries
    An object up on a Shelf has more potential energy than the same object on the ground.
    A hot object has more energy than the same object when cooled.
    I think I will put my batteries up on the roof in the Sun.
    900W, 40A MPPT, 230AH FLA,24V Samlex 1500W
  • max2k
    • 819
    trouble is that energy cannot be easily converted to electricity. Besides, you'll spend energy lifting them up the roof.
    it would be more efficient to put some workout bicycle next to your bank on the ground, wire it up to the system and bike away: you'd lose some weight and also generate some electricity .
      • 15005
      Hey Max: Like Sunking implied, you got potential kid, but learn to think out of the box a little. Take it from someone who's been an engineer for 40 yrs. or so:
      I'd get around the lifting part altogether by digging a hole deep enough to put the roof at ground level and put a semipermeable membrane around the hole (impermeable to everything except the house that is), and then perform a spatial inversion with respect to the hole and its surroundings. That will put the house in the hole and save the work of elevating the batteries.
      You gotta' be an experienced engineer to come up with that one.
      Don't say I never gave you anything.
      • Gdwats
        • Jul 2017
        • 207
        It was a joke. Just emphasizing how elecical stuff seems new to me, even though I'm sure I studied it at some point. Just never sink in it seem too weird and it was like just part of a course decades ago. I am having a lot of fun learning/relearning it though.
        • Gdwats
          • Jul 2017
          • 207
          About the bike..the pedal/gearing system could also be used hoist the black boxes boxes up.
            • 15153
            Too bad batteries can't store power just sitting in the sun light. It would make it easier to store all that energy.
            • Gdwats
              • Jul 2017
              • 207
              Indeed. And when they run low with no sun, just set them on the ground to release all that potential energy.
                • 15153
                Perfect analogy.
                • max2k
                  • 819
                  I see, experience is hard to hide I think there's small problem with this solution- how ppl living in the house would get in and out or is this left for the rest of the staff to figure out ?
                  • max2k
                    • 819
                    It was a joke. ...
                    what a bummer- we almost got it solved
                      • 15005
                      No problem at all. As you may remember, all the best problems were "left as an exercise for the student." Little did we students know at the time that the "later" for most problems, and for most of us, was after we got jobs.
                      Actually, it's no problem and not to worry. All those folks in the house need to do is need to do is shrink to (1-P.F. of a running motor), but only after startup, tilt their body at arcos (P.F.), duck into the imaginary plane with the rest of the lost power and sneak in/out through the lost power conduit.
                      To get back in however, will take an inverse Laplace transform. Otherwise, everyone will be inside out. on their return.
                      Glad to be of service
                      • max2k
                        • 819
                        but of course, how could I miss that?
