High voltage DC contactor
    Someone was asking about HV DC contactors suitable for disconnecting a 48V battery bank (so you'd need a 60V rated relay.) All Electronics is now selling a TE Connectivity relay (intended for EV's) for $39. 24VDC coil, contacts rated 500 amps 900 volts. (Cat # SOL-205.) Should be enough for almost any battery system.
  • max2k
    • 819
    that thing can disconnect anything around the house and in the area
