Charging a car or lawn tractor battery off of my setup
  • Basketcase
    • Oct 2016
    • 50
    Hey all. I have a small off grid setup at my camp. I think the array is around 200 watts and I have 2, 6v 230AH golf cart batteries in series and I run phone chargers and a few led lights with it. Occasionally it would be nice to be able to charge a dead car battery or lawn tractor battery without having to fire up the generator (which has a 12v charge output). Is it against the rules to just use jumper cables to hook up a battery to my bank for charging and leave it for an hour or so? My instincts tell me NO but I can't find any info on it when I search. My thoughts were that if it is really discharged, it would try to pull a lot of current from my batteries and cause a problem.
    • 15151
    It would not be a smart idea to charge a car battery from your solar battery system. First off you will need about 15volts to charge that car battery and you only have 12volts in the solar battery. Even if you had a higher solar battery voltage (24v or 48v) it would still not be a good idea to use them to charge a car battery. It would quickly drain them.
    Best way to charge the car battery is to get it started and let the alternator do the rest. You can do that by jumping from another car or use the generator and car battery charger to get it high enough to restart the car.
      • 2331
      Nope. As SE mentions it won't do a good job of charging those batteries, but if your goal is to jumpstart the car that will work. WARNING - if you go battery to battery you will have no protection at all, and if you short the cables you will do a lot of damage. It would be much wiser to jump from the downstream side of the fuse to the battery to be charged.
        Won't work worth a darn, but a good way to start a fire if you are cold. It can be done, and can work, but beyond DIY capabilities. Screw up and you will have a fire on your hands or an exploding battery.
        Now they do make Electronic Battery Isolators for boats and RV's that have an Emergency switch so one can charge the vehicle SLI battery from the House battery to get you going.
        Never mind, I edited out how to make it work. To dangerous.
        • Basketcase
          • Oct 2016
          • 50
          So I gather that if I want to do this, I would need to disconnect my bank and connect my charge controller directly to the discharged battery? Probably easier to just use the generator. Are there chargers that take a 12v (or 14v while the array is charging) input? Is there a device I could get to perform this operation? Here is why a solution to this would be good. This is on an island with no power. Just off grid solar. There is one truck on the island so jump starting it from another car is not an option. We deliberately purchase only manual transmission vehicles so we can push start them if we need. We buy a new $500 truck every 10 years or so. It gets used very little. More common is a dead lawn tractor battery and we all know that the charging systems on mowers are not meant to charge a dead battery. For these reasons it would be really beneficial to have a separate "charging station" for other types of batteries. If my array can bring my other battery bank up to voltage, I dont see why it cant do the same for a car battery. I just need to figure out how to do it safely. A current limiting charging system of some sort would be perfect. Something that would allow the battery to charge slowly. I suppose one option is to use an inverter and a plug in charger, but I feel like that is not the most efficient way to do this.
            • 15151
            You can use your solar pv system to charge the car battery but it may not do it quickly enough depending on how much it has been discharged.
            A solar charger is just that. It expects power from solar panels and not another DC power source.
            Always remember is takes a charging source to produce about 15 volts to charge a 12volt battery. That is why a 12v battery will not work to charge a 12v battery.
            There are manual generators that are attached to a fixed bicycle. They are called Peddle Power. Bikes I do not know what the output is from the generator but that may be another way to get those small lawn tractor batteries charged back up again.
              • 5205
              Letting a starting battery get discharged and sit a long time is a great way to destroy it. Here such batteries (backup
              generator, etc) are on MAINTAINERS, which feed a small current to keep them in a good state without overcharging.
              They are not for charging a battery, the appliance does that when it runs. You need a solar powered maintainer setup,
              designed so it draws no current when there is no sun. The smallest ones on the market were too small for me.
              Bruce Roe
                Yes that would work, should not take more than 3 days
                A generator with a good automotive fast battery charger is the best option period.
                Assuming the generator is at least 1000 watts or larger, you would want to have a large as a 12 volt battery charger as possible. By large I mean 30 amps or higher. The higher the amps, the faster it will charge. Here is why, it is simple math. You typical SLI car/truck battery is 60 to 90 AH capacity.
                Amp Hours = Amps x Hours
                Hours = Amp Hours / Amps
                So if you have a 60 AH battery, and a 30 amp charger it will take 60 AH / 30 A = 2 hours. If it were a 60 amp charger than just 1 hour.
                • Basketcase
                  • Oct 2016
                  • 50
                  Thank you. For the moment, If I have to do it I'll use the generator. I cant find the specs for what the generator produces on it's 12v side but it's a 2k watt Generac inverter generator and I used it to charge the battery last week. The battery ended up being junk anyway but I used one of those tiny little (freaking amazing) jump packs to use the truck for the day. Just had to jump it each time. I have to admit, this little jump pack is great. About the size of a cell phone but twice as thick. It jump started this old v6 5 times and charged off a cig plug on our solar at 2 amps in a few hours and I used it again the next day. But yet my samsung is dead by 4 pm. Go figure.
                  • max2k
                    • 819
                    I respectfully disagree- it sounds like OP just wants to get car started. That process takes much less charge: 100A x 30sec cranking about 1 Ah. He doesn't need to get battery fully charged- just enough to start the engine and then car charging system would take over. With his 200 Watt solar it should be able to produce 10A charging current which would bring good battery to the starting state in about 5-10 min. The key words here are 'good battery'- in my experience car batteries gets discharged beyond starting point for some internal problem and that very same problem would prevent it from taking charge in the first place so the end result would be the same, just for completely different reason.
                    • max2k
                      • 819
                      That is not theoretically correct- in my past I designed sources which produced higher voltages than the source for charging purposes- one would just need some reactivity in the circuit, inductor were widely used for this purpose. That's not to say that I can produce model number of such charger or know where to get one.
                        • 5205
                        He said 12V to 12V. Inserting another device to produce a higher voltage is a different situation entirely. Bruce Roe
                          Thank you. For the moment, If I have to do it I'll use the generator. I cant find the specs for what the generator produces on it's 12v side but it's a 2k watt Generac inverter generator and I used it to charge the battery last week......
                          Generally, that 12V output is only a couple amps, good for charging a motorcycle battery. A 20 or 30A charger plugged in will do you a lot better
                          20A @ 14V = 280w x2 (poor efficiency in most chargers) is 560w or about 840w for a 30a charger
                          • max2k
                            • 819
                            if inductor is grounded from some input voltage source with some switch and then disconnected it behaves as current source and can supply load with any voltage from close to 0 to tens of volts still keeping the current. All I'm saying is this problem was technically solved probably decades ago and with modern electronics can be made small and efficient.
                              • 5205
                              We all know that; I designed and built such circuits in the 60s. Has nothing to do with SunEagles statement. Bruce Roe
