Great as that gives you another LVD option using an external BMS.
Options and more options to work with. All this means is you can do LVD externally, or internally on your Inverter. You gotta figure out which way is best for you. All I can do is consult and call out the Pro's and Cons allowing you to make an informed decision. I am not making a penny off you and unlike a salesman I am not going to push the more expensive options influenced by a commission. However I would never turn down a check for helping.
