Charging 6v bank with 12v solar
  • CanadianDIYer
    • Oct 2013
    • 3
    Hey i am new to this site and looking for some info. I am making a portable solar generator with 4 6v batteries wired together to make 12v. That is easy however my 15A charge controller only has one battery charge terminal. So with the 2 sets of 6vs how do i connect the charger so that both sets charge? Can i just run 2 wires from the same port of the charge controller?
  • Naptown
    • 6880
    You need to connect your batteries in a series/ parallel configuration. This is not the best way to set up a bank.
    Search connecting batteries on the diagonal for more detailed info
    • CanadianDIYer
      • Oct 2013
      • 3
      Yes i was planning on going with a series parallel set up however even looking at the diagonal set up where would be the best spot for me to put the charge wire to charge the bank. If i was to put in in series parallel form it seems like i would need two charge points and looking at diagonal it still seems like 2 charge points would make sense. However i am new to this and could easily be missing something.
      Thanks again for the advice.
      • CanadianDIYer
        • Oct 2013
        • 3
        Ok so i have finally found a well written post for the "simple Jacks" in the crowd for the proper diagonal wiring for 4 6v batteries and proper charge points thanks again.
