I want to set up a camera for time lapse photography at a remote site and leave it unattended for extended periods of time. This camera is fairly easy on batteries to begin with, two AAs last for 250+ photos, and if I kill the LCD screen can probably get a bit more. Anyway, what I want to do is get a cheap battery (I'm thinking SLA), and hook an inverter up to it which the DC adapter for the camera can then plug into and voila, more power than the AAs provide. The camera DC input says 3V, FYI, but I'm not sure how to figure out what each picture actually draws, and it may not be possible given the variations in autofocusing and light correction, etc.
On those same battery terminals that have the inverter attached, can I latch on a solar battery charger? This doesn't have to be pretty or fancy, and it can't be expensive or the wife won't think my pictures are worth it... I just want it to be functional. Will the camera basically drain the battery with the solar panel topping it off maintaining a constant charge, assuming the camera doesn't draw more than the solar panel provides? Is it okay to connect the charging cables and draining cables (for lack of better words on my part) to the same terminals on the battery?
Excuse the crude image, but this is what I was envisioning. Is the theory of what I described correct, or am I way off and setting myself up for a meltdown of equipment?
I searched around the interwebs and on here and found things for security cameras, cameras with a laptop, cameras with remote control... nothing quite as basic as what I'm trying to do. Any suggestions or thoughts are appreciated.
