East Penn 6 Volt Golf Cart Battery - Gp GC2 from carquest -- is this any good?
g110 - 12 batteries are the same as the East Penn Deka batteries?
They might be close, but they are NOT the SAME. Do you have mfg g110 - 12 manual for them ? That's the preferred setting to use,Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
James read this STICKY. Use your hydrometer to tell you what voltage to use. In fact read all the stickies in this sub forum.MSEE, PEComment
