How to use load function on solar charge controller?
  • ewarnerusa
    • Apr 2016
    • 142
    Hello,
    I have never quite understood how the load function works on many solar charge controllers. For example, I'm looking at a 60A rated MPPT controller that offers a load function up to 20 amps. I know what a diversion load or dump load is to divert unused current into a heating element. But I don't think that is what these typical load functions on solar charge controllers do. Can someone explain it for me? Thanks!
    I'm an RV camper with 470 watts of solar
    • 15157
    Usually the "load" output on a charge controller is for some low wattage lighting. Turning on the output is different for each controller.
    • Bala
      • Dec 2010
      • 734
      I have a controller in my off grid system just for the load function. With this controller i can set low v cut out and a cut in v. Essentially i use it to switch off the non critical loads if there is not enough sun.
      Using relays and contactors i run a 240v pump on a timer, a 24v to 12v reducer, a 24 night light and v meter.
      • littleharbor2
        • Jan 2016
        • 231
        Sounds like a Trace/Xantrex C series controller in "Load Control" mode.
        For the loadout function on small charge controllers are meant for small, many times, timer controlled loads. Don't ever connect a big load like an inverter to this output, go straight to the battery.
        • Bala
          • Dec 2010
          • 734
          No, its a Plasmatronics PL40. The load function is controlling coils on relays, so only milliamps of load on the circuit.
          • ewarnerusa
            • Apr 2016
            • 142
            What is the trigger for when load function comes on/off?
            • Bala
              • Dec 2010
              • 734
              I have it set to turn off at 24v
              It will not turn back on until 28.2v
              It also had a 10 minute time delay, so a spike to low or high setting will not trigger.
