Looking to move from two lead acid batteries to one lifePo4 and want to cut down on connections. Using appropriate breakers/fuses, can I take my roof solar, solar on the side, and inverter connections and run to a positive and negative bus bar and then one wire to the battery terminals? Just confused on current flow and whether the inverter and solars would be working against each other.
Bus bar usage
