Hi everyone, I’m facing an issue where I have 2x 160w panels on the roof of my car which are wired in parallel, when assessing the amps together they are making less amps then individually, the panels work perfect individually but when together produce less current.
Both panels have a bypass diode in them, but it seems like when wired in parallel one panel is acting as a load hence taking away almost half of the expected current.
The solar then flows unregulated into a redarc bcdc1240 which is capable of taking up to 28volts.
Any ideas as to fixes will greatly help!
Thanks
Thanks
