25 Watt Panel with 100Ah battery
  • bouree
    • Jun 2021
    • 4
    From the sticky named "12 Volt Design and Safety Considerations" it would seem that using a 25 watt panel to charge a 100Ah (10hr) AGM battery is a no no. The post mentions that the charge rate should be a minimum of C/12. In my case I am yet to pull the trigger on purchasing my 100W panel(s), but I bought the battery and MPPT 20A controller and am planning to give it a change with my existing 25W panel - understanding that it will take a while.
    I am mostly tinkering with the aim of learning and with the final goal to have backup power for small outages and also have something for overlanding.
    What is the downside of charging with a smaller panel other than time?
    Thanks!
    • 15153
    Thanks!
    The downside is not giving the battery enough charging amps so it then sulfates and slowly dies.
    A trickle charge (via small panel or charger) is ok once the battery is full but not good if you try to recharge a battery that is less than 95% SOC.
    • bouree
      • Jun 2021
      • 4
      Good to know - Thanks!!
