Two panels fitted at different angles on van roof?
  • jp11
    • Jan 2021
    • 4
    I'm contemplating fitting two 175w Renogy flexibles on the roof of my high-roof Mk8 Transit. This van has a large sloping section to the front of the roof above the windscreen (sorry, I'm from Ireland), windshield if you like. This to make use of low sun angle when parked (we have a lot of low sun here!, and very often no sun).
    This may produce differing outputs from both panels. Will that be an issue?
    • 5215
    You may connect them in parallel since the voltage varies little with sun intensity.
    Series NO, since they will usually produce different currents. Bruce Roe
    • jp11
      • Jan 2021
      • 4
      OK Bruce, yes I would have them in parallel. So I guess they'd simply be producing different wattage?
        • 5215
        Watt = V x A, so different amps (depending on sun) will give different wattage. Bruce Roe
        • jp11
          • Jan 2021
          • 4
          Ah, thanks Bruce. Of course, a light bulb moment for me. The panels produce current, not watts. Watts are what we consume?
          • Weldman
            • Oct 2019
            • 58
            And of the two panels the one producing the most wattage/amps will be dragged down by the one getting the least amount.
            1.2 kWh solar 10.56 kWh battery @ 24v in a RV
              • 5215
              If you mean best sun panel voltage dragged down when in parallel, does not happen.
              The best sun panel is operated about 80% of open circuit voltage for the most power.
              The poor sun panel will also try to reach open circuit voltage, but when it hits the 80%
              value, it will contribute its minimal output current to the load. Neither panel takes
              power from the other. If they could, practice would be to include blocking diodes, but
              that is not required. Bruce Roe
                This is true when both panels have similar Vmp. ( another thread has a poster with a ~250W panel & ~80W panel, which are not likely to match well
                  • 5215
                  Yes, the beginning post stated 2 apparently identical panels. To match up operating
                  voltage, I go more by the number of cells, than the single point published Vmp. Here
                  a string of 10 each 72 cell panels is paralleled with a string of 12 each 60 cell panels.
                  Bruce Roe
                  • jp11
                    • Jan 2021
                    • 4
                    So are we saying that there is no benefit in mounting one of the two identical panels at a different angle?
                      • 5215
                      That is too simplistic a statement. I have panels mounted at 3 different orientations
                      and 3 different angles, driven by things like my inverter sizes, net metering agreement,
                      and the frequent clouds. What works for me is not optimized for you. Bruce Roe
