Thanks to Mike90250, Wrybread, and little Harbor my original trailer solar powered fridge system has 3 years of flawless operation!
So I'm looking at semi duplicating this system to run a mini fridge in the bed of my truck for an overland rig set up:
Knowns:
1) Fridge runs about 210W at start up and settles down to about 100W after a minute or so of operation.
2) I'm going to run 2 Costco Interstate -6V GC batteries in the bed so I'll have about 230Ah of battery storage.
3) I'm going to make a direct run off the trucks alternator with a relay (auto or switched) to charge the GC batteries when the truck is running so they should be full a lot because I'll be driving a good amount of the time.
4) looking at getting about a 200W flexiable solar panel off Amazon to charge the batteries when camped.
Questions:
1) looking for recommendations for a cheap 20A solar charge controler with USB plugs on it from either eBay or Amazon (not sure if I need MPPT or PMVwill work)?
2) looking for recommendations on a Switched or Automatic relay for the battery charging system off the alternator.
3) looking for recommendations on cheap sub $200 flexiable solar panel.
4) I want to put the flexiable panel on a 20ft to 25ft teather with a plug at the batteries and just plug the panel in when camped to charge the batteries and unplug and store the panel when driving. What's the formula/chart wire diameter required for this run using something like this panel?
https://www.amazon.com/Monocrystalli...exible+solar+p anel+200w&qid=1597701040&sr=8-67
If you have any other recommendations I'm all ears.
Thanks
Knowns:
Questions:
Thanks
