starting off small but turning into more
  • Ho jo
    • Nov 2017
    • 156
    With 400 watts all aimed in the same direction my amps peaked at 26.
    In a SE SW orientation peak amps would be
    less.
    A 100 volt 30 amp controller would be well matched.
    • redbank
      • Jun 2020
      • 10
      So if I used a branch connector and positioned two 100w panels SE and two 100w panels SW and used my better CC (rated at 400w maxium input power and 42v maxium solar input voltage) I should be okay? The CC notes there is an overload protection if it matters.
      Second question, if I find myself running my single 105ah 12v battery low during a weekend with bad weather do I wire it up in series or parallel?
        With the specs you mentioned earlier, you can only run all 4 panels in parallel. 2 in series would overvoltage the controller
        • redbank
          • Jun 2020
          • 10
          maybe you are not understanding my question or the connector I want to use.
          https://www.renogy.com/4-to-1-solar-...mf-ffffm-pair/
          This should put them all 4 in parallel, series if I understand would be to attach one panel to the next panel and so on.
            • 15179
            Those cables will create 4 panels wired in parallel but you will now need to include individual fusing for each panel. Just using that cable is not safe.
              Wire the panels in parallel. you can use the branch connector.
              Wiring panels in series does nothing for you but waste a panel.
              • redbank
                • Jun 2020
                • 10
                I do have an inline fuse.
                I want to thank everyone for their help and time. much appreciated.
