Hi all!
I'm building a system to run a low powered USB device 24/7 (it draws 1Ah at 5v per day).
Originally I was going to use a 6v solar panel -> USB powerbank (with an 'always on' mode) -> device.
However, the 6v panel doesn't put out enough juice, and larger wattage 6v panels are almost non-existant.
I'm trying to make the system as lightweight as possible, and my best idea currently is 12v 20w panel -> charge controller -> 20aH motorcycle battery -> 12v to 5v buck converter -> device.
I've considered using a li-ion battery to get the weight/size down, but it seems like the controllers for small batteries only charge at low current (for example: https://www.adafruit.com/product/390)
My question is, is there a better way of achieving this than my current 12v setup? Perhaps a li-ion type solution that I am missing?
I have also seen some charge controllers that have a USB output on them, would I be better to use one of those, rather than a separate buck convertor?
Another thought - could I use a 12v charge controller with USB output, have no 12v battery connected, and just hook the USB connector to a powerbank? (I *think* that controllers always need a battery connected, but may be wrong).
Thanks!
Thanks!
