Combiner and Cirtcuit Breakers for RV?
One of the next things I want to do is research building these wood panels so as not to catch my RV on Fire. There’s got to be something like Rubber washers to give spacing so its not on wood directly, I’d like to leave room for expansion later so that this could become a 24V system.Comment
Your breakers and combiners are in the same box. This is the midnight box I used. The breakers are available in 1A increments
You can see the bus bar at the top of the breakers, that combines all the + circuits, and the side termial for all the minus leads.
Breakers http://www.midnitesolar.com/productP...tOrder=1&act=p
A local vendor buys the 12 packs and splits them up for you
All you need is a rated raintight box with DIN rails for your breakers. I don't know if a horizontal version exists. Otherwise, you have to bring all the leads into the RV and combine there
I actually have the very same combiner box, the midnight solar 6 input, but looks like a possibility of a leak if I use it lying it horizontal. The only way I can figure out how to use the Midnight Solar combiner would be to wire all six of my panels with wiring going through the roof via pipe to the battery compartment. I bought it thinking I'd put it on the roof of the RV.Your breakers and combiners are in the same box. This is the midnight box I used. The breakers are available in 1A increments
I think there's got to be systems available that are water tight. I've seen some pictures of house roof mounted panels that have what appear to be a combiner that lays horizontally.
I've got a few months before I start drilling and cutting, but I started today, I would not use the midnight solar panel, because I don't want to run six sets of wires through the roof, I'd rather just use two. I can kind of see a path forward where I build a 24 V system, but I would probably need a 12V battery still to run the electronic breaks, and still need something to charge that 12 volt battery, so that might not be a good idea. Especially for a first project.Comment
