Using a lifepo4 to charge or jump starter motor battery
+ More Options
Posts
  • solaar
    • Nov 2016
    • 31
    Is there any potential issue with wiring up a lifepo4 to a lead acid starter battery in parallel:
    1. To give a top up charge to the starter in the case of the vehicle sitting for a while;
    2. To charge up a starter battery too flat to turn the engine over;
    and 3. To jump directly off the lifepo4?
    I have a little portable 60 ah lifepo4 I use for various things, and would be great to just hook up the jumper leads every now and then to give the starter battery a top up. In the case of flat battery too, obviously this would be helpful.
    Thanks.
    • 15155
    Thanks.
    You may be correct. I have a "jump start" portable battery. While I believe it is AGM type I have used it to jump my car when it's own battery was too low to start it. So it may be possible to use different chemistry batteries to "jump" a vehicle's battery. But I do not think just using a parallel wired set up to keep an FLA battery "up to charge" is a good idea because both batteries will eventually discharge just sitting there.
    • solaar
      • Nov 2016
      • 31
      Thanks Sunking, discharging won’t be a problem, the lifepo4 has a solar regulator attached, so I can keep it topped up with the panel on my trailer. I was more concerned with the FLA somehow damaging the lifepo4, but if that’s not a real concern then it should be ok. It’s not going to be an ideal voltage for the FLA, but it should at least be able to get a float level charge and figure that’s better than nothing. I live in the camper, so it all gets monitored very regularly.
        • 15155
        Just remember that solar is never 24/7/365 so there will be some days the Lifepo4 will not be charged by the sun.
        IMO if you really want to keep the FLA batteries charged then use a solar charging trickle system for them instead of the Lifepo4 batteries charging the FLA.
          I don't see an issue doing that temporarily. I agree with @SunEagle that the best arrangement would be to trickle charge the starting battery with solar. That way it stays topped up all the time.
          • solaar
            • Nov 2016
            • 31
            Just had another idea: forget about the lifepo4 - I have a double cigarette lighter outlet near the front of my van coming from an AGM battery charged by solar at the rear.
            Is there any reason I couldn’t just wire up:
            Cig lighter male connector
            to a length of 15 amp wire
            to alligator clips
            When I want to charge the starter battery I could just plug the cig connector in and clip to the battery, effectively making a parallel connection between the two batteries. Just not 100% sure about going through the load output on the cc.
            I was avoiding using the AGM because I didn’t want to route more cable, but in the case of the cig lighter outlet, that job is already done.
              If your car battery is low, it can suck a lot of juice from any jumper type battery. Most lighter sockets have a fuse in the vehicle fuse panel, often 20A. be ready to replace it,
              • NewBostonConst
                • Nov 2018
                • 113
                to alligator clips
                I have used two of these small solar panels to keep two of my batteries topped of in a backhoe and truck for the last year. I got them off amazon.
