Can I bond/ground to the structure of a steel building?
  • Farman
    • Jun 2019
    • 11
    Still quite new at this stuff, and I'm trying to clarify a grounding idea. In my fiddling with small 12v solar setups, I continue to think along the lines of automotive circuitry, except that I've always floated the negative polarity back to the batteries. Hope I said that right.
    So if I have a little 12v system being used in a pre-engineered steel building, could I use the building just like a car's chassis?
    If I'm understanding the concept correctly, I wouldn't have to use twice the amount of wire.
    The problem with using your building for a ground instead of some type of ground rod can result in electric shock should someone be touching the building metal and standing on the earth during a fault. It is always better to have a path for the fault to ground to go though using wire and steel instead of a human.
    • Farman
      • Jun 2019
      • 11
      I should have mentioned that the building is attached to ground rods that are driven into the earth. Does that change the safety issue you bring up?
        I would refer to NEC for starters. How far is the nearest ground rod?
        • Farman
          • Jun 2019
          • 11
          From what?
          The ground rods are within a foot or two of the building's foundation wall. The nearest rod to the battery bank would be about 15 feet or so.
            I would NOT use the building ground as a minus return . You have screwed joints, paint, weatherstrip and the inherent higher resistance of steel over that of copper.
            Plus the safety factor.
              I would run a ground wire from the solar system to one of those building ground rods. It would be safer to have a direct path to ground then to go through the components of a metal shed.
              • Farman
                • Jun 2019
                • 11
                Case closed.
                Thanks for the input, it really does help.
