Hi, i have a couple of things that will be using "Shielded wire" & needs grounding/earthing. Should this be taken to the steel bodywork/chassis as it not quite earth???.
Shielded wire & grounding
I take it, this is a mobile application, like an RV or a bus ?
You can tie the negative battery to chassis, but for high amp loads, don't simply run a + wire, run both - & + cables, sized to carry the load. Too many interfaces where painted chassis front frame is bolted to mid frame, bolted to painted rear frame. Or spots were rubber vibration isolators are used, and you won't get good current flow in the chassis.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Hi, thanks for getting back. Yes, it on an RV & it was the small shielded monitoring cable that comes from a shunt on the battery monitor & also the casing of a ham radio.Comment
