Battery monitor question? TM-2030 vs. Whizbang Jr.? Or both?
  • PNW_Steve
    • 433
    Hello Everyone,
    As I am piecing together the solar design I have made a few purchase that seemed safe. One of those was a Trimetric TM-2030 battery monitor.
    I had planned on a Victron MPPT charge controller and the TM-2030.
    In another thread it was pointed out to me that I may benefit from running the Midnite Classic and Whizbang Jr. I am leaning strongly that way but am wondering if I should ditch the TM-2030 in favor of the Whizbang or should I install both? Any benefit to having both?
    Thanks.
    S.
    Simple battery monitors without a shunt, are only able to make a wild guess, as to the actual state of the batteries. Using a monitor that counts amps IN vs amps OUT can come very close to being accurate.
    • littleharbor
      • Jan 2016
      • 1998
      Victron Has their own shunt based battery monitor. FYI.
      • PNW_Steve
        • 433
        Ok.
        Since both monitors I asked about each use a shunt and I am going to use the Midnite Classic....
        What do you recommend?
          Originally posted by PNW_Steve
          Ok.
          I do not use a shunt, I rely on experience and battery voltage (NiFe bank) for my self. I have a classic, and am active on the Midnight Solar msg board http://midniteftp.com/forum/
          From my time there, the Whiz Bang Jr is a very fine shunt, when installed properly and intergrates well with the system, mostly for measuring End Amps to complete a charge cycle.
          I don't recall if the Midnight WBJr actually totals In vs Out.
