Hi, i need some advice, i bought a 27 year old motorhome which has a 36 cell solar panel on the roof, it's sealed down so can't see any information.
When i bought the MoHo recently there was no charge controller for the solar panel, it was just connected directly to 2 batteries, which one is dead ...... so i bought a 30A PWM solar charge controller and a new 12v/125Ah leisure battery, i put a tester on the solar panel to check polarity and voltage, the voltage shows about 19v coming through, but wont show the Amps.
I connected everything up and the Icon shows for the solar panel but it's not charging the battery
i also recently purchased an MPPT Blue Solar controller 75/15, so decided to install this just in case the PWM controller was faulty, when i connect the battery the green LED shows, but when i connect the PV panel the yellow light does not light up, i've also checked to see if the wires were connected correctly.
Is the solar panel damaged due to having no controller before?
any help would be appreciated.
TIA
Gary
TIA
Gary
