I tried the Genasun GV5, which was small, light, and had great features, but with one fatal drawback: it passed panel open circuit voltage (about 18V if I recall correctly) to the battery terminals when the battery was fully charged. I think this was because the GV5's BMS conflicted with the battery's BMS.
The battery documentation says that the inbuilt "PCM(protection circuit module) will disconnect the battery if the input voltage gets to high, so although you were seeing 18 volts at the battery terminals the PCM should have disconnected the battery terminals from the battery. I think it would be worth contacting th battery manufacturer to check what voltage the PCM disconnects the battery from the terminals and what is the maximum voltage you can apply to the battery terminals before you damage the PCM.
Can someone recommend either: 1) a small, 4-cell LiFePO4 battery that has internal balancing and no BMS; or 2) a small, light MPPT controller with good LED status lights and no BMS?
Simon
BMS - Homemade Battery logger https://github.com/simat/BatteryMonitor
Latronics 4kW Inverter, homemade MPPT controller
