Minimum to Comfortable Setup for stationary off grid caravan
  • Tashi
    • Oct 2015
    • 27
    Judging from the conversion wiki for AWG, 6mm2 Wire falls between 9 and 10AWG so this wire should be ok for 10 to 15 metre run.
    and a couple of normal plugs on one end because it is in series.
    I am not worried if I cant use it for a few days because of weather conditions.
    I will have a closer look at the battery and Controller. Are you familiar with any good controllers with an LCD in that price range? Am i silly wanting an LCD? it seems to me that it would be useful for seeing how many ah in and out over time in particularly. anyway i will check reviews.
    Thank you so much for all your help
    • PNjunction
      • Jul 2012
      • 2179
      Dude, your ebay shopping is killing me. I could easily counter with Amazon links.
      How about this - why not link direct to the manufacturer's site, and let people find their own deals or buy directly. Kind of like this:
      Morningstar manufactures and supplies solar charge controllers and inverters. Over 4,000,000 off-grid solar products deployed globally since 1993.
      Samlex solar charge controllers regulate incoming solar power to protect your batteries and prevent overcharging. Learn more.
      MidNite Solar offers a large variety of alternative energy products from E-panels to charge controllers and inverters.
      You'll get far more information from them vs just throwing darts at the online shopping bazaar.
      • Tashi
        • Oct 2015
        • 27
        Originally posted by PNjunction
        The voltmeter is critical
        I saw some with a clamp as well as the probes but they seemed to have less choices around the dial.
        Are the clamps useful and are two in one units ok?
        • Tashi
          • Oct 2015
          • 27
          Killing me softly with your links
          Thankyou good idea. I will check them out
          • PNjunction
            • Jul 2012
            • 2179
            Heh, most of those meters are crap.
            You are investing a lot of time and energy into this project, so don't cheap out here. Why buy a Ferrari only to replace the tires with retreads from the gas-station? Oh, they may work, but do you TRUST them?
            I can personally vouch for this inexpensive lineup from Fluke - their 11x series, and the 114 would be my bottom line. (no current measurements). Step up to the 115 if you want 10a current measuring as well.
            Ideal for most electricians, the Fluke 114 Electrical Multimeter is CAT III 600 V safety rated & is a compact true-rms meter for any troubleshooting.
            Or, perhaps better for your area:
            Ah, that's better. Spend just a little more on even a low-end Fluke, and you won't regret it, or wonder if it is really all-that. It is.
            • Tashi
              • Oct 2015
              • 27
              I can get that for $250AUD so these extra measurements and better accuracy will translate into better efficiency, accurate diagnostics and longer system life?
              • LETitROLL
                • May 2014
                • 286
                It depends, if you are still going to buy the $9.99 DC-DC converter to charge your laptop because your budget is too small to afford the better one for $39, then yes it is very silly. Solar panels themselves for the most part are pretty good and trouble free, just have to take care to avoid dropping/breaking them yourself, but the rest of a solar system (controllers, batteries, etc.) especially at the budget entry level are not like a TV and other electronics in the home that most people are used to just plugging in and having them work flawlessly for 10 years, with inexpensive solar setups there are more issues and a much higher percentage of people that end up "in the dark"
                • LETitROLL
                  • May 2014
                  • 286
                  My only problem with the LCD is the fact that it is "value added" to an average (at best) charge controller to make it sexy and attract sales. The charge controller is the heart of the system and critical to reliability, longevity and how much power you have to use each and every day. With a tight budget that you have expressed you want to stick with, I just like to see every dollar go to function and production. I just looked on ebay.au and they have inline volt/amp LCD meters that give you that same information (and in color) starting at about $4.99.
                  • lkruper
                    • 892
                    I have been wondering if putting a kill-o-watt meter inline with the inverter output combined with a notebook would allow the collection of statistics similar to an LCD. Could that be a poor-mans battery monitor?
                    • LETitROLL
                      • May 2014
                      • 286
                      Should work fine, the Kill-o-Watt meters seem to be pretty good at keeping all the running totals, and with pure sine inverters it shouldn't be able to tell any difference vs grid power, not sure how the Kill-o-watt would see Modified sine wave?
                      • lkruper
                        • 892
                        Good question. However, I think what is more important is that it report consistently. If a record is initially made of what loads were powered and for how long, it might be possible to calibrate it. The problem I had when trying this in a very small experiment was that I ran the small battery down to the point where the inverter shut off and I lost the data. If the system used by the OP is scaled properly, the idea is that this would never happen, correct?
                        • Tashi
                          • Oct 2015
                          • 27
                          I am happy if I get the VICTRON 75/15 MPPT - 12/24V Solar Charge Controller that you suggested and the inline Digital LCD Watt Meter Battery Balance 60V100A DC RC Volt Ammeter Amp Analyzer.
                          So then I have a decent controller and an accumulative reading. Were would I wire in the inline meter? and is it something I could swap in and out if I put it on plugs?
                          • Bala
                            • Dec 2010
                            • 734
                            While Flukes are always nice to have I dont own one and never have. Have had one in a workplace. I have used from the cheapest meters to one I have now is about $60 aud. i have run my solar system for almost ten years as well as using them for work as a mechanic. In the workplace where we had a fluke it was professionally calibrated every year. You can check your own meter against your regulators meter to ensure its accuracy, or lack there of.
                            Personally I dont think its necessary to spend $250 aud on a meter for a home solar system.
                            • LETitROLL
                              • May 2014
                              • 286
                              Most of those are easy to wire in, they just take a sample voltage from wherever you put it, if you want to know gross power output from panels you would have to y into the panel input wires at the controller, or if you want to know what is actually making to through to your batteries, then y it into that output that goes to the battery. Most people leave them in the circuit, but i don't know of any reason you could not put quick disconnect plugs on it, its just a meter. I think that will give you a much better setup for actually less money (hard to beat a double positive).
                              • Tashi
                                • Oct 2015
                                • 27
                                Hi thanks for all the good info i am getting some confidence back in this project
                                I found a local battery supplier with a 12v 120ah FULLRIVER DEEP CYCLE AGM BATTERY 31 SIZE for just under $400. Fullriver seem to have some good reviews around the place and the eBay seller only has 1 negative. Is there anything important I should look out for when looking at specs like this? especially in regard to my system?
                                Cycling Capacity
                                20 hour rate 120 Amp Hours
                                Reserve Capacity
                                @ 25 Amps 200 minutes @ 75 Amps 45 minutes
                                Mechanical Specifications
                                Group Size 31
                                Terminal Type M8 (w/ TP08 Brass AP Included)
                                Total Height 8.66" (220 mm)
                                Height 8.43" (214 mm)
                                Width 6.77" (172 mm)
                                Length 12.91" (328 mm)
                                Weight 72.3 lbs (32.8 kg)
                                Case Type ABS Plastic - Flame Res Rating UL94-HB
                                Discharge Table (Constant Current)
                                Time Amps Rate
                                20 hr 5.8 0.05 CA
                                10 hr 10.4 0.1 CA
                                8 hr 11.9 0.13 CA
                                5 hr 18.2 0.25 CA
                                3 hr 27 0.33 CA
                                2 hr 33 0.5 CA
                                1 hr 62.1 1 CA
                                Electrical Specifications
                                Nominal Voltage 12 Volt
                                Capacity @ 100 hour rate 130 AH
                                Capacity @ 20 hour rate 120 AH
                                Capacity @ 10 hour rate 108 AH
                                Capacity @ 5 hour rate 94 AH
                                CCA 760
                                CA or MCA 910
                                Short Circuit Current 2830 Amps
                                Internal Resistance 3.8m Ω
                                Charge Voltages
                                Battery Voltages
                                Charge Stage 12V 24V 36V 48V
                                Bulk 14.7 V 29.4 V 44.1 V 58.8 V
                                Absortion 14.7 V 29.4 V 44.1 V 58.8 V
                                Float 13.6 V 27.2 V 40.8 V 54.6 V
                                TC Factor: -4mV/°C/cell
                                Temperature Range Specifications
                                Condition Recommended Maximum
                                Storage -15°C to 50°C -40°C to 71°C
                                Operation -15°C to 40°C -40°C to 71°C
                                Charge with TC -15°C to 50°C -40°C to 71°C
                                Charge without TC 0°C to 40°C -15°C to 50°C
                                Terminal Torque Specifications
                                Terminal Type ft-lbs in-lbs Nm
                                AP | DT (AP) | M6 | M6M (stud) | TP07 (AP) | TP08 (AP) 4.2 - 6.0 50-70 5.6 - 7.9
                                FR45 6.0 - 7.5 70-90 7.9 - 10.1
                                M8 7.1 - 8.0 85-95 9.6 - 10.7
                                DT (stud) | M10M (stud) 9.2 - 10.4 110-125 12.2 - 14.0
