I know everyone here prefers the expensive name brand charger/controllers, but I'm on a tight/small budget. I can't afford to pay the same price for a controller that I do for a couple panels. I was looking at getting an AGM 12v battery, was hoping for a 150ah but may have to settle for a 100ah. I was also planning on just getting 1 - 150 watt panel. I understand that AGM's have different charging requirements than FLA's, but I'm not fully understanding what they are.
When looking at inexpensive charger/controllers, usually the only settings you can change are the voltage at which they stop charging (and I assume go into float charge), and 2 under voltage settings that relate to load, and I won't be putting the load thru the controller so that doesn't matter. Is this one setting enough to be able to use them with an AGM? When people ask the 'can it be used with agm' question, the answers always say something like"no, it says it's for lead acid NOT gels"...... and that doesn't really answer the question, since they ARE lead acid, just sealed instead of vented.
On a side note, I saw this one on ebay that says it's an mppt/pwm unit, and is a little more expensive than a standard pwm, but not that much. I have a feeling it's not really an mppt... any knowledgeable comments? They have a pretty ambiguous statement regarding it: (Controller Provided MPPT Maximum power point tracking Function, charging mode is PWM)
Link: http://www.ebay.com/itm/New-LCD-10-2.../111411804592? (it's to ebay, hope it's ok to post the link)
Thanks in advance for whatever comments are given.
