Hello everyone
I registered here to begin discussing the configuration I have put together for camping. I wanted to build a portable, modular system that can be set up and taken down easily. I want it to be able to run small entertainment options, radio, maybe a laptop, a couple small fans for keeping cool. and some string lights.
The concept revolves around using milk crates for the batteries and electronic components so they can stack and transport easily in the truck.
I have two 12V 35ah batteries in each milk crate, in parallel. They are then connected via the quick connect to create a 12V 140ah power source. All power source cables are 4ga.
I'm using the Harbor Freight solar power kit for the solar power (3x15Watt) 45watt array and the included charge controller (It has a output cutoff of 11V and a charge cut off at 14.5 V)
For the inverter, I'm using a Samlex 600 watt pure sine wave inverter
My dilemma is the charging process. I cannot get the batteries up much past 12.1 volts. 12 V should take up to around 13 when FULL? They were 12.4 when I originally tested the inverter load. I ran two fans (70 watts total consumption) and some minimal LED light strings. Voltage dropped from 12.4 to 11.3 in 6.5 hours without simultaneous charging (night scenario test)
I'm using a balanced connection for the inverter. Positive connection at battery #1 and Negative connection at Battery #4
Here are my questions:
Do I hook up the charge controller to the OPPOSITE of the balanced configuration ( Positive at Batt#4 and Neg at Batt #1) or do I connect the charge controller to the same terminals that the inverter is connected to?
My Batteries charged back to 12.1, but I can't get them back up to 12.4V (almost 13V FULL)
My other concern is that the 45 watt input from the panels may not be enough to push this battery connection to a MAX charge. ( I wanted to test the charge controllers shut off point and it never got there.
Sorry I don't have the knowledge to provide a wiring diagram, but here are some pics. I would appreciate any input.
Thanks10423291_10153277027145129_3416043312191862639_n.jpg1467357_10153277027100129_3978789664864325029_n.jpg10277650_10153277027095129_972326580751331785_n.jpg
