Hi - new member and total amateur here looking for a little help. Thanks for any help in advance.
I have a little project to build a solar powered heat ventilation fan for my garage. I have a 12 volt fan that draws 2.5 amps so I bought a 12v 30 watt panel. I understand that the panel will actually generate more than 12 volts (just measured it at 20 volts using my multimeter) so I thought I would be smart and put in a 12v voltage regulator to step down the voltage to the fan.
What I ended up with was a little device that functions as a combination solar charge controller and voltage regulator. I assumed I could connect the panel to the panel inputs and the fan to the "Load" outputs (no battery connected) and I would get a nice 12v output. In reality I'm not getting anything through "Load" so now I'm thinking that this little device is wired to generate the "Load" output from a connected battery and not as a stepped down voltage from the panel directly.
Can anyone confirm this? If so, what is the standard/common way that folks use to ensure they are only getting 12v from a panel?
Thanks again,
Bob
Thanks again,
Bob
