I was originally thinking that I would need to scrap the built-in "Converter" which currently is the DC Load and Charging source when AC is supplied to the trailer.
I am investigating all the equipment I need and my end goal is to increase the trailers battery bank and add PV Panels. So now I want to look for the most efficient setup which would supply AC and DC load from Shore or Gen when connected and when PV Panels are below minimum output use the (Shore/Gen) DC supply to continue / start charging.
Question is, can I supply an MPPT controller DC from Converter in place of PV source and it do so only when PV is down and Converter output is available?
I want to have one device that is in control of bank charging and that device have optional DC sources, and control which source is supplying that device.
Is it efficient to keep the Converter and disable its charging (which mine has no parameter control but is a 3 stage) and have a setup which would only utilize an "Inverter" when (Shore/Gen) is unavailable, however the Converter would be used and Inverter off when (Shore/Gen) is available.
I am worried about having true control of the bank's charging, I don't want to have to keep up with and match multiple chargers based on my current DC source.
Another DC Source is the Vehicle when connected and traveling, which is then tying in the trailer bank to the vehicle's alternator, Would this connecting need to be modified to route thru new setup as well?
[Clarification]
I understand having more than one source or input to one MPPT controller is going to cause the MPPT to freak out when trying to calculate Pmax=Imp*Vmp. I am suggesting having an automated/Manual input control where "only" one source is supplying the controller.
I guess I could break out my old Parallax Basic Stamps and control some relays myself?
[Clarification]
