Hey folks!
It's been almost two years since I built a panel using Clear Seal. Figured it was time to give another update, but I see the thread has been closed.
My last update was here:
Anyway, just took the readings a bit earlier 7.51 amps and 19.24 volts. A little bit down, but I'm still happy. And the sky does look a little hazy today.
I can't see any corrosion but it looks like the captured bubbles may have moved and coalesced a bit. Those darned mineral spirits may never completely dry out
. That could be a good thing. If they're not getting out then the water should be having a hard time getting in
P.S. maybe a mod could tack this post onto the old thread?
