I've ready mixed reviews online about using silicone with plexiglass. Some say it works, some say it won't hold. Anyone here has any experience with it? If it works what kind? I have a tube of GE Silicone II btw. Suppose I can test it, but even if it works right away I won't know if it will still hold 3 months later...
Does silicone adhere to acrylic (plexiglass) well?
You will have to look that up in the Mfg's data sheet. Reports I've heard from the fish tank groups, it does NOT bond well. For a PV panel, where you don't have 50 gallons of water pressing on it 24/7, it might hold enough. Clean with water first, then with alcoahol - if it's not clean, it won't stickPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
You will have to look that up in the Mfg's data sheet. Reports I've heard from the fish tank groups, it does NOT bond well. For a PV panel, where you don't have 50 gallons of water pressing on it 24/7, it might hold enough. Clean with water first, then with alcoahol - if it's not clean, it won't stickComment
