HELP About This Encapsulation !!!
  • onnow78
    • 13
    hi friends ,
    I found an item which was using for encapsulation of electronic parts at Turkey .
    the name is Arensy Enerji Yalıtım sistemleri , izalasyon re
    The encapsulant needs to do 2 things
    physically protect the cells and interconnects, with the same rate of thermal expansion, or be flexible enough to allow differential expansion
    Water Vapor barrier. few things are "tight" against water vapor. Glass is one, Tedlar is another. most epoxies and silicone sealers are not.
    • onnow78
      • 13
      Detaİls are at the new photos
      thia is one of my friends panel the encapsulation is ok
      • timmanufacturer
        • Apr 2012
        Silicone sealant is a good option for you to do encapsulation of solar panel.
        Simon - contact user JASON to submit advertising application.
          Sorry, you must contribute something of value, before you are allowed to have commercial links in your signature.
          Silicone sealant is NOT good for PV panels, as it allows water vapor to pass, and will build up steam & condensation inside.
          • timmanufacturer
            • Apr 2012
            Sorry, it is my mistake.
            There is a kind of silicone pouring sealant with two components, when they are compounded, it will be solidified. When temperature is higher, the speed of solidification is quicker. By the way, the silicone sealant is usually used to seal gap but not encapsulation. The solidified silicone pouring sealant is softer than epoxy resin, right?
            • Rick Rinehart
              • Apr 2012
              Where can I buy Dow 6010 sealant
              Seems to be the best out there but I can seem to find a source to buy from. Suggestions?
              Rick
