Epoxy Resin and Other Encapsulants
+ More Options
Posts
  • Woody
    • Oct 2011
    • 4
    Epoxy resin is used to encapsulate PC boards. Why not use it as a coating on both sides of the cells, then you can adhere with whatever you want to. You can thin epoxy with 10% acetone for a thinner coating but I don't think that it would be necessary, or advisable. West marine 105 has a UV stable hardener that stays clear. About $100.00 per gallon retail. I find it hard to believe that this has not been tried in the industry at some point. Anyone know of testing from one of the labs? Has anyone tried this approach?
  • Woody
    • Oct 2011
    • 4
    Has anyone tried to have the cells between two pieces of glass with a vacuum in between, or argon gas? That would help to solve the thermal issues as well.
      Argon leaks out in 10 years, in factory made, dual glaze windows.
      Vacuum woudl be even less lifetime, and allow no heat transfer (themos bottle)
      • Woody
        • Oct 2011
        • 4
        Thanks Mike.
        What about a glass "sandwich" with a replaceable (every X years) of desiccant through a threaded connection?
          Windows are a far, far bigger market than solar panels - if that type of thing was practical it would already be done.
          • Woody
            • Oct 2011
            • 4
            Russ,
            Thank you, I see your point. No one I know would think of the interior of windows as having to have maintenance. However, possibly a DIY type solar panel without having the expense of the encapsulation might easily trade the maintenance for the cost of encapsulation. Aren't we talking about a small amount of water vapor over a long period of time here to actually penetrate the seal?
            I am thinking that a soda straw sized desiccant inside, between the glass panes through a copper 3/8" tubing with a simple cap on the outside of the seal, (straw glued to the cap). I am going to do an annual inspection of any DIY PV panels anyway, why not require an annual desiccant replacement on a hot summer day?
            I know that when striving for an absolute for a long period of time leads to exaggerated expense when a lower cost maintenance would serve the purpose just as well.
            I think way "outside the box", and large portion of those thoughts are absurd, and will not work. Is there a reason that you can think of that this would not work?
            Thanks for your time.
            • digimart
              • Nov 2011
              • 101
              So after such a long discussion, we have had here, do we arrive at some acceptable solution for encapsulations ?
              I understand that while opting for DIY we may be sacrificing a little, but if the cost-benefit ratio is positive, then its a doable transaction.
              [B]Omar S Chaudhry[/B]
              DigiMart
              Lahore
