Hi there,
I have started to build a 72 cell panel. I have my backing made, the perspex and the cells all soldered. I am now looking for a good resin type that will last for years without going yellow or crack. Can you help?
I will proceed to a back encapsulation: Line the cells onto the backing plate, use glue to make them nice and flat then pour a layer of resin that just covers all the bumps, let it dry, then add another layer before applying the perspex on top, one end first then lower the other end slowly to avoid any bubble.
I have not seen this technique anywhere so I will make a small test with some off cuts first.
z.
z.
