Hello everyone,
This probably sounds vary silly to you guys. but please help. New to solar, New to electric and trying to do it myself.
I have a Lensun 100W 12V Black Fiberglass Semi-Flexible Monocrystalline Solar Panel from Amazon
https://(https://www.amazon.com/Lens.../dp/B01HA4TVLM)
Learned that the wire comes with it is vary short with MC4 connector with them.
I plan to install this panel on my van, just to power my mini fridge continousely (Whynter 65 Quart Portable Fridge Freezer)
(http://www.whynter.com/wp-content/up...on-Chart-1.pdf)
One of PWM Solar Panel Controller from Ebay
(http://www.ebay.com/itm/12-24V-20-30...72.m2749.l2649)
Please advice & questions:
Understand the Benefits of PV wire(temperature and water resistance) , however, I will drill a hole right under the wire form the solar panel into the car (the wire comes with the solar panel is long enough to get into the car). Do you guys think if I can do just fine using apple computer extensions cord from apple inside my van to the battery,( Yes, that is right, Just have too many of them in my house right now, I would like to utilize them)
What are your guys suggestion on battery, I am thinking to get 2 6-v c 105 re batteries. Yes. I may use this system to power 2 12-v fan if I happen to sleep in my van
(http://www.trojanbattery.com/pdf/dat...ata_Sheets.pdf)
Do you guys think this would be an overkill setup for the Whynter 65 Quart Portable Fridge Freezer? only one applicaton my van. Or I should just get 1 12-v gel cell, AGE. or battery, which require less maintenance.
Thank you.
Thank you.
