electrical varnish for solar cell encapsulation
  • axis11
    • Mar 2011
    • 237
    Hi,anybody have an idea if electrical varnish will work as encapsulant for cells?
    If it worked well in the long term, commercial panels would use it.
    • axis11
      • Mar 2011
      • 237
      pls. excuse my ignorance. maybe you could tell me more about the effects of this varnish.If it could keep my panels running for ten years,its ok. Maybe you have an idea around how long will cells sandwhiched between glass and plywood produce at least 50% of their power.
        2 years in a high humidity area would be excelent for home brew panels, in my opinion.
        When they start to fail, I expect the end would come soon, rather than a year later.
        The coating and the cells, must be the same themal expansion, or be flexible enough to not damage the cells. Varnish, I expect, would quickly flake and peel off. And it's not clear, it will reduce the power the cells can produce.
