I have been trying to build about 4-5 200 watt panels for the past 2 months now to see if I can do away with these ridiculous charges from the power company but was put off by the total expenses, I mean the best I could do was $3/watt so it didn't seem to be worth the effort to me. It seems that encapsulating the cells (ie. sylgard 184) is the biggest contributor(I would have needed about 4 jars of the stuff for each of the panels). Using epoxy just didn't seem appropriate, for starters it yellows over time and it is too rigid and at this level of investment that was not going to work. I did a search online and came up with this
They claim that this solartite is just like sylgard but it is much cheaper(they are offering one jar for about $35) so i decided to try it out. I also bought some 1.5x3 solar cells to test this solartite in a 10 watt solar panel diy. The mixing of the stuff goes like sylgard, 10 parts of the base to 1 part of the curing agent(even smells similar). So I built an aluminum frame(bought from home-depot), integrated the usual lexan sheet and poured the stuff in. It started to get thicker and set after a few hours and when it was done, the finished stuff was just like sylgard, couldn't tell the difference between the two. The 10 watt panel is looking very nice. I'll upload some pictures when I get home.
Now that the initial test of this solartite is complete, I want to move on to the main project but I'll appreciate some input from those with more experience with this kind of stuff, in particular if you have ever used this solar-tite before or if you have past experience with building solar panels, please help
