Well, it's not my forum, just my thread
Yes, I have made one of my three panels and I did use the Clear Seal.
I tried something that didn't work well and I don't recommend it. I tried doing it in two pours and I only thinned the sealer at about 2/3's CS to 1/3 mineral spirits then laid the strings of cells on top of it. I ended up with quite a few bubbles to work out.
That's where I learned my second mistake, I forgot to wear a good respirator.
I was working outside under a covered porch, but that still wasn't enough fresh air.
By the time I'd gotten to the last few cells, I was so stoned and sick that I just didn't give a D@%^$ any more. So I still have bubbles.
After giving the panel a week to dry, I came back with a 50/50 mix of CS and mineral spirits which was poured over the backs of the cells. Despite the bubbles between the glass and a few cells, the panel seems well sealed.
You can see how the panel is preforming here:
It's been up a few weeks now and is doing great. Right now we're having the first real rain since the panel was mounted. I'll check it when things dry up, but I'm not worried about it.
You could consider the panel to be on a tracker now, it's on the top of my van
I'm still getting use to the idea of NOT parking under trees. Between the shade and the birds it's just a bad idea.
But the bonus is I can run all the fans I need all of the time!
Originally posted by tlgoose
