Different Colour Solar Panels
  • steevieboy4u
    There could be a few reasons for the different color. Depending on how they are wired to your inverter you might be able to determine if one is not producing or is faulty.
    How is your system wired and do you have any electronic monitoring?
    Hi, it's wired 2 strings of 8 panels. The inverter is a SOFSR 3680TLM Wi-Fi version. This doesn't show any faults and has the normal green LED when it on. The voltages in each string can vary up to and over 30v but I'm not sure how accurate these are and how fast it updates as sometimes it's string one that's low other times it's string 2 and I would have thought if the one panel was faulty it would always be the same string that was low?
    Cheers for the reply
    Originally posted by steevieboy4u
    Stumbled across this thread and wondered if you found out why some of the panels were different colours and had water on them as I've got the exact same problem with just one of the 16 panels I've got fitted. They were only fitted 3 months ago and I'm concerned that the one that is a different colour is faulty
    See photo above
    Thanks
  • steevieboy4u
    Panel Colour
    See photo above
    Thanks
  • steevieboy4u
    Panel Colour
    I've also got the same issue and my panels were only fitted 3 months ago, there is one that is a total different colour and I reckon its defective!
    What was the outcome of this as I know this thread is quite old now?
    That whole array looks a little funky to me. What's happening on the upper right side ? Looks a bit undulating. Also, What's w/ the shadow pattern under the array. Looks more checkerboard than a solid pattern of closely spaced panels would produce.
    I have seen other installations that do not keep all the panels level but follow the geography of the land. I guess it depends on what the cost would be to have all the panels level or have some not face exactly the same direction.
    As for the spaces. To me the panels look like there are 3 rows with spaces in between therefor no shadow on the ground. From the angle of the picture you can't see these spaces but if you look at the panels in the back they seem much smaller than the ones in front if they were all butted front to back.
    Since it is not a roof installation and is very big in size, having a way to maintain the land between the large rows is usually the way these systems are installed.
    As for the color? Could be a lot of reasons, from panel degradation on a few to light reflection.
  • Lorin
    Based on what?
    Because I have a seen some panels like this in my city. Also my friend's house has this view.... and he doesn't have any problem at all.
    Originally posted by mojo34.5
    Please check photo under the rain and panels showed dark blues and the water were cumulated on surface. Someone explain ?
    [ATTACH=CONFIG]3933[/ATTACH]
    Looks like some panels have a coating and some don't......
    Originally posted by Lorin
    I don't think is anything to worry about...
    Based on what?
  • Lorin
  • mojo34.5
    started a topic Different Colour Solar Panels
