Understood and I agree 100%. I've been doing some research and have discoverd I'm most likely using the meter wrong and could probably stand to use a better one too. I guess just touching positive wire on meter to positive on solar cell and same with negative is not advisable. Without a resister, I'm not going to get a good reading on the meter. Am i on the right track here?
Noob! Noob! Noob! - regarding the Grail - Where's the best deal on Cells please?
You can measure the voltage that way but not the current. That requires the cell to be connected to a load like a resister or even the charger will do. You would then use a DC "clamp on" amp meter to measure the current going through the positive or negative wire.Understood and I agree 100%. I've been doing some research and have discoverd I'm most likely using the meter wrong and could probably stand to use a better one too. I guess just touching positive wire on meter to positive on solar cell and same with negative is not advisable. Without a resister, I'm not going to get a good reading on the meter. Am i on the right track here?
Do you have a DC clamp on amp meter? If not then there are other in line type that have the proper electronics to measure the amperage as long as the cell is connected to some type of load. They can be purchased from a Radio Control Hobby store since there are a lot of RC that use electric motors and batteries.Comment
Well....good news is my solar panels should be alot stronger than i thought they were unless i have fried the cells by improperly measuring current. They still charge my batteries so i think they are fine. I need to invest in a decent meter i think, mine doesn't have clamps and was only about 10 bucks. Thanks for the info.
