Different voltage panels
  • KhellQc
    • Feb 2016
    • 4
    Hello all, before you answer please read.
    Ive done research and I know the putting panels with different voltages together isnt advised. BUT every time I find an exemple, with with really big differences.
    I have 5x 48w panels = 3.02A 15.9V rated ( 3.35a 19.8V max)
    but 1x 100w panel = 5.9A 17V rated ( 6.5a 21.6V max)
    I run a 12v system ( 12v Charge Ctrl ) so i got them all In parallel
    Questions;
    1 - Its not 18v with 36v OR 12 with 24v ( double the V diff ). We re talking about 1.1V. In my case, Is it as bad as everybody says on the internet ??
    2 - The real reason of my post is that I am thinking about buying an other Panel to the lot; 1x 90w 5.17A 17.4V rated ( 5.58a 22.58v max)
    --- which would make a 1.5V difference with my 5x 15.9V. I am scared its going to draw down the New 17.4 making it see too many Amps and
    wearing it down faster
    3 - I feel limited to that one panel because all others are around 18v rated making 2.1v higher, which scares me. Should I worry ?
    4 - am I wrong to think that the charge control being PWM so my understanding was that it limited the panels to what was needed thus making okay to
    mix my voltage a bit???
    Thank you all for your help!!
    15.9V, after it passes through a charge controller, is not going to be able to fully charge a battery. Only if your loads are very light, will this work for more than a couple weeks
    • KhellQc
      • Feb 2016
      • 4
      Loads are light and has been running the system for months now. Its meant to charge cellphones and run laptop with the battery off. With full sun batteried are charged within 2 hours. But panels are facing SE and want to add one SW.
      Thanks for your concerns but still doesnt help me with my confusion regarding parallel panels with SLIGHTLY different voltages.
        Originally posted by KhellQc
        ....Thanks for your concerns but still doesnt help me with my confusion regarding parallel panels with SLIGHTLY different voltages.
        The slight differences in voltage will not be an issue. The voltage you will actually see under loading, will be the voltage of the lowest panels. 15.9V
