I just finished my first homemade solar panel. After purchasing the cells, and charge controller off eBay for less than 100 bucks, I realized that the cost of building the frame could exceed the cost of the cells and I was just basically building a window box.
I found a dual pane vinyl window for $5 at the Restore (that's the Habitat for Humanity's resale of donated and used building materials). I took it apart, removed the dual pane unit and cut the foam tape out from the bottom. I had mounted the cells on a piece acrylic sign plastic. The plastic sheet was then slid into the dual pane unit and resealed at the bottom. The unit was then reinstalled into the vinyl window frame.
Attached is a photo.
