Hello,
I have a small solar system built for backyard water pump and I realized today that the charge controller is only giving 2.0 volts to the battery.
The open circuit voltage of the 50w panel reaches a maximum of 9.2 v in a sunny day and that is not good enough to charge the 12v 2AH SLA battery. I had to get a DC to DC booster to bring up the voltage to 24 volts and that is what's going in the charge controller. I realized today the output of charge controller going to battery is only 2 volts. I brought the charge controller in the house and connected it to a 12v dc adapter and I received the same output of 2.0 volts going to the battery from the charge controller. The charge controller is a fully capable of handling the voltage and amps going in.
I am not sure whether the charge controller has been fried or not ...
Regards,
David T. Suzuki
Regards,
David T. Suzuki
